3 members (TUTS 59, JW51, Jon G),
114
Mod | | | Forums66 Topics128,095 Posts1,056,480 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 33 New Guy | | New Guy Joined: Jul 2008 Posts: 33 | The front directional signal along with the inside dashlight is not working (right side). The rear is working properly (flashing). I am not getting voltage to the light or coming out of the firewall plug or the connector underneath the dash. Could it be in the mechanism under the steering wheel? Is there something else I need to check? Parking lights are working fine along with the left hand signal front and rear. Thanks in advance.
Leon Stallings Hartsville, SC 1965 Chevy C20 LWB 1965 Chevy C10 LWB
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy valk2001, I think that by all the checks you have made so far, you have confirmed there is a problem with the turn signal switch under the steering wheel, good luck. | | | | | Joined: Jul 2008 Posts: 33 New Guy | | New Guy Joined: Jul 2008 Posts: 33 | Yep, it was the plastic switch under the steering wheel. Replaced ans all is well. Thanks for the info.
