1 members (dunfire), 129 guests, and 1 robot.
Topics128,132
Posts1,056,732
Members48,454
V
V Offline
The front directional signal along with the inside dashlight is not working (right side). The rear is working properly (flashing). I am not getting voltage to the light or coming out of the firewall plug or the connector underneath the dash. Could it be in the mechanism under the steering wheel? Is there something else I need to check? Parking lights are working fine along with the left hand signal front and rear. Thanks in advance.
Leon Stallings
Hartsville, SC
1965 Chevy C20 LWB
1965 Chevy C10 LWB
3B Offline
Hy valk2001, I think that by all the checks you have made so far, you have confirmed there is a problem with the turn signal switch under the steering wheel, good luck.
V
V Offline
Yep, it was the plastic switch under the steering wheel. Replaced ans all is well. Thanks for the info.
Leon Stallings
Hartsville, SC
1965 Chevy C20 LWB
1965 Chevy C10 LWB
