| | | Forums66 Topics128,196 Posts1,057,385 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 15 New Guy | | New Guy Joined: Feb 2007 Posts: 15 | I'm a looking into placing an early Chevy cab & nose on my 85 K30 4x4 frame. I would like to find out how wide is the normal width of these trucks. I need the outside edge to outside edge of the stock tires. Also, how much more fender overhang from outside edge of tire to outside edge of fenders. I am looking at any trucks from 41 to 53, trucks 1 ton & up. If you post a measurement please list what truck it came from and if you have stock tires. Thanks
~Boone 1932 Confederate 5 window Sport Coupe 1936 Chevy 1/2 ton pickup 1953 Indian Chief 1947 Indian Chief 1946 Indian Chief
Collector of Vintage Indian motorcycles pre '1953
| | | | | Joined: Aug 2008 Posts: 82 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 82 | a lot of those specs can be found here - click on the "trucks" link.
1956 Chevy 3600 Dually
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | What make, year, & series truck are you going to use the cab, & front clip from. A '47-'54 GMC 450,or 470 series will have the widest front axle track, but will also have larger, wider fenders, than a 1 1/2, or 2 ton Chevy, or 300, & 350 series GMC. | | | | | Joined: Feb 2007 Posts: 15 New Guy | | New Guy Joined: Feb 2007 Posts: 15 | I am open to whatever fits as long as it is a CHEVY and it is 53 and below. I need to tuck up 80 inches of axle & tire (outside edge measurement) to make it look right. I only own the 85 right now and it seems the big bolts are still out there and cheap.
