7 members (hdgeren, NJC, Wickedbass, Gone, Otto Skorzeny, rfs56trk, Peggy M),
53
Mod | | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 17 New Guy | | New Guy Joined: Jan 2008 Posts: 17 | I am looking to replace the wiring on my 1958 apache with a 235. I would like to retain the original generator for now and go with a wiring kit that has a fuse block.....most vendors seem to recommend going to an alternator first. Is there an issue with using a newer wiring arrangement (fuses)in combination with a generator system? | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | The only problem is a lack of adequate current capacity. Most stovebolt generators are either 25 or 35 amp units, so if you have enough accessory equipment to exceed that current draw, the generator will be running at full output all the time, and the battery will have to make up the difference. Some current hogs are electric cooling fans, high-output headlights, and some types of climate control systems with high current draw blower motors, A/C clutches, etc. Sound systems with high-wattage amplifiers put lots of load on an electrical system, too. Jerry
| | | | | Joined: Jan 2008 Posts: 17 New Guy | | New Guy Joined: Jan 2008 Posts: 17 | my intent is to stay pretty much stock so should be ok for now..........thanks for your help | | |
