| | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 29 'Bolter | | 'Bolter Joined: Nov 2007 Posts: 29 | The dist. is wobbling but runs good. Does it need a rebuild or buy a new one? HEI? were to buy one? The up draft carb (carter) has a flat sport in it. rebuild or a new one were? Thanks 7M | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The distributor wobble is normal at idle. I wouldn't worry about that. | | | | | Joined: Oct 2006 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 40 | The HEI distributor conversions are great if you can get one that has been remachined properly. There is a guy on EBAY that sells tons of them--but avoid him at all cost. His call name is HEIDIZZY on Ebay. DO NOT BUY ONE FROM THAT GUY!!!!! He has screwed everyone he sells to. Jim Carter Classic trucks carries an HEI conversion but I don't know how good they are.
I have seen rebuild kits and the entire updraft carbs on Ebay as well. | | |
