0 members (), 170 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
The dist. is wobbling but runs good. Does it need a rebuild or buy a new one? HEI? were to buy one? The up draft carb (carter) has a flat sport in it. rebuild or a new one were? Thanks 7M
The distributor wobble is normal at idle. I wouldn't worry about that.
1951 1 Ton Completed
The HEI distributor conversions are great if you can get one that has been remachined properly. There is a guy on EBAY that sells tons of them--but avoid him at all cost. His call name is HEIDIZZY on Ebay. DO NOT BUY ONE FROM THAT GUY!!!!! He has screwed everyone he sells to. Jim Carter Classic trucks carries an HEI conversion but I don't know how good they are.
I have seen rebuild kits and the entire updraft carbs on Ebay as well.
The aviation artist guy in Houston that loves old trucks even more than planes. www.jasonbarnettartist.com
