7 members (mick53, Tiny, Southerntruck, HandyAndy, TUTS 59, 2 invisible), 82 guests, and 2 robots.
Topics128,093
Posts1,056,046
Members48,433
#71994 01/20/2007 4:35 PM
I have a 12 bolt rearend out of a 67 1/2 ton truck that measures the same width as my original torque-tube rearend, I know that the original axle is not centered & that I will have to move it back 1-1/2" to 2".
My question is, I know I have to mount new perches on the axle, the rear springs measure 1-3/4" wide, would the be a problem using a perch thats 2-1/4" wide. I'm looking at a perch thats used for off road, they are long enough that I can drill the locating hole & offset the rearend to the back.
Here's a pic of the perches I'm looking at, http://memimage.cardomain.net/member_images/1/web/1969000-1969999/1969206_73_full.jpg
thanks.
#71995 01/20/2007 6:36 PM
It looks to me that they are well made and would work fine.I even asked my wife and she agrees,longer and wider is better.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#71996 01/21/2007 1:52 AM
Those would probably work. CPP (1-800-522-5004) sells the 1-3/4" perches, or a whole kit including u-bolts and shock mounts. They also have a centering plate for your application.
#71997 01/21/2007 4:36 AM
using a wider purch will cause issues with the axle U bolts that fit around the axle and go thru the new (as sold available kits) plate that is under the springs (unless you the plate holes are suited for your width) connects all this together. this plate also connects the shock to the frame support.
Ps I moved my axle back 2 1/2'' so the under bed tank fit and I believe it looks better than the 1 1/2'' spacing.
heck you'll need a new drive shaft any way.
view of my 2 1/2'' offset saddle::
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=Scan1_0001-1.jpg
Jim & Caroline
