7 members (Charles in CA, Otto Skorzeny, Lonnie, 1955 1 Series, dt235sd, Wickedbass, 1 invisible), 125 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#719924 02/10/2011 7:44 PM
Need the experts..is there any way to identify starters? Numbers etc. have two starters. One with Delco remy no.'s from a 53 3100, and another without tag from supposedly 56 truck both stomp type. I believe they both have nine teeth on Bendix drives. Would appreciate your expertise. Much appreciated...Sepp.
Plattelnjpichler
sepp22 #719960 02/10/2011 9:27 PM
3B Offline
Hy sepp22, one way to tell a six volt starter from a twelve volt starter is, the six volt starter has a larger diameter armature shaft. That is the reason we can't just swap starter drives when we want to change from six to twelve volt starter. A quick way to know one from the other if they still have tags is, a six volt starter has a black tag, and a twelve volt starter has a red tag, hope that helps.
