8 members (msmall, 68ironhead, Shardean, DannyW, Eisenholtz, 3800GUY, Shade Baby, cmayna),
41
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | I'm working on cleaning my door window channels, rollers and manual crank. My question is what lube should I use for said parts. I know years ago my choice would have been white lithium grease, however in recent years I have not been pleased with it's results. It seems to "gum up" and not lubricate well, if at all. Any suggestions?
Thanks | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | grease does collect the grunge in the air, dry graphite in the channels can be helpful and a light application of an anti-corrosive spray on rotating parts usually works well enough
Bill | | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | Thanks for the response. I didn't think of dry graphite, it seems like a clean way to do it. A fella told me he uses anti sieze, but that seems real messy..... at least when I get near it.
Thanks again | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Best thing I have found for the window channels is this product. Go to NAPA and pick up a can of "CRC Heavy Duty Silicone multi use lubricant". It sprays on like carb cleaner but does a fantastic job on the window channels...NO FUSS NO MUSS NO SMEARS OR FUNK. It does not collect dust and dirt also. My new channels were so tight my power window motors were struggling and blowin fuses a good soak with this product and WHALLLA!...problem fixed!..and that has been 2 yrs. ago..NOW THIS PRODUCT IS TO BE USED AFTER PAINT!..IT IS SILICONE! Tim
| | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | SW, Thanks. That sounds exactly what I'm looking for. | | |
