7 members (Rusty Heaps, mason86, Peggy M, wilbur53, ndkid275, Otto Skorzeny, 1 invisible), 115 guests, and 0 robots.
Topics128,050
Posts1,055,676
#718833 02/07/2011 12:52 AM
hello i have a 54 3100 4 on the floor i want to add reverse lights does any one know a cheap easy way to do it
thanks
Just a suggestion, install light run to toggle at dash.
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800 :: In the Stovebolt Gallery
More pix on Flickr
Duwop #718970 02/07/2011 2:37 PM
Yup, thats what I did. Cheap and fast.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
glasman #718973 02/07/2011 2:49 PM
Ex Hall Monitor
Ex Hall Monitor
That's the way the early vehicles were wired, a separate switch.
Tiny #718980 02/07/2011 3:02 PM
The toggle-switch seems to be the easiest method.
There was a back-up switch made for SM420 transmissions (available in 1967) and there was/is a back-up switch that could be used on the shifter-pivot inside the engine compartment for 54/55 Hydra-Matic transmissions.
Supposedly earlier SM420s could be adapted to use the 1967 switch; but, the one for the H-M was/is a bolt-on. Sorry, I do not know part numbers for either switch.
http://67-72chevytrucks.com/vboard/showthread.php?t=181306
http://www.advanceadapters.com/tech-vault/gm-sm420/
http://www.jeepshots.com/shots/projects/sm420/
http://talk.classicparts.com/showthread.php?t=7345
omegaone1954...hope you dont mind me jumping in here.
I was just curious where, on the AD trucks are the guys who add reverse light mounting them? under bed... stake side?
What size/type fixture are being used?
Anybody have a pic?
I would like to add them on my 50 also. Backing up in the desert the other night made me realize this would be a good Idea.
Toggle switch would work for me, with indicator light.
DADS50 #719120 02/08/2011 1:04 AM
thanks toggle switch will work, not a prob i'm going to hide mine under the roll pan
4 speed should have a seperate shift rod for reverse. What about mounting a pushbutton switch to where it tripped when the reverse shift rod tripped it when in reverse position.
Greg_H #719148 02/08/2011 2:31 AM
Hi Dads50. I have used backup lights from a early 50s chevy. I made plates and mounted them on the rear bed pocket. I liked them. They lit up behind the truck.
Dennis
Actually, there was a backup switch available for the SM420 in 1955 on the 2nd Series trucks. It consisted of a collar with a tab for the switch that mounts to the shift tower, then a cast aluminum peice the mounts to the shifter to activate the switch. It is all external of the transmission. The same swithc was also used with the 3 speed manuals, as well as the Hydramatics. If I can remember where i put the instruction sheet that came with the NOS backup lamp kit I used on mine, I'll scan it and post.
Bill Burmeister
Ill look around for a fixture. maybe a 4inch would work.
DADS50 #719186 02/08/2011 4:43 AM
I mounted a set of chrome Guide B-31 backup lights w/ brackets on the rear bumper brackets. A fellow Stovebolter sold me a nice set of lights! I ran wire along the frame into engine bay, then in behind dashboard. Bought + installed a vintage illuminated light switch. I'd share pictures, but have yet learned how to do that here.
fonz8261 #719190 02/08/2011 4:52 AM
I would like to see a pic of that set up. I have my spare under the bed.
DADS50 #719248 02/08/2011 1:58 PM
sent you pm--do not know how to post pictures to the Forum
fonz8261 #719266 02/08/2011 3:41 PM
Ex Hall Monitor
Ex Hall Monitor
Check the IT Short Bus forum. There are a couple of stickies there to guide you. They are at the top of the threads in the forum.
Tiny #719579 02/09/2011 12:53 PM
Bill I'd really like to see a scan of those instructions.
Denny G
Denny G
Sandwich, IL
I was fortunate enough to have a spare 4-speed trans., with the reverse switch set up attached. I want to put it on my truck, but the depression switch is bad. Can't seem to find a replacement so far, that is affordable.
Tiny #720227 02/11/2011 11:02 PM
Tiny, Thats a sweet ride hence the name Sweetie
More pix on Flickr
Duwop #720254 02/12/2011 1:16 AM
Ex Hall Monitor
Ex Hall Monitor
Thank you. The bank account is considerably smaller now. grin
