8 members (55shaker, Bruce 1954-4100, Hanks custodian, Gdads51, BC59, Cletus1950, cmayna, 3800GUY),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,109 Posts1,056,253 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | Have been working on getting my 46 3/4 ton apart and am almost ready to pull the engine.Just have a couple of questions.Will it be easier to split just behind the clutch and pull the motor (all front body metal and rad is off) and leave trans in place? There is a frame cross member for support at that point. Question 2 is that this truck has an open driveline and a pto on the trans as it was set up as a dump box, did the 46 1/2 tons have an open driveline? This is a canadian built truck so has a chev 216 in it instead of a 228 GM and 4 speed trans. Thanks Murray | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | my 46 1/2 ton is a closed driveline. I found it easier to pull the engine unbolting it from the trans and taking it out with the bellhousing attached, a lot easier to get the clutch,flywheel and bellhousing off while its hanging on the hoist. You can always pull the trans afterwards and bolt it onto the engine when it comes time to put it back in, if you don't like struggling to get the input shaft lined up if your by yourself.
