5 members (FAST55, Phak1, Gib70, DadsFirstPickup, Bill Hanlon), 135 guests, and 6 robots.
Topics128,108
Posts1,056,231
Members48,436
#719382 02/08/2011 10:10 PM
Have been working on getting my 46 3/4 ton apart and am almost ready to pull the engine.Just have a couple of questions.Will it be easier to split just behind the clutch and pull the motor (all front body metal and rad is off) and leave trans in place? There is a frame cross member for support at that point. Question 2 is that this truck has an open driveline and a pto on the trans as it was set up as a dump box, did the 46 1/2 tons have an open driveline? This is a canadian built truck so has a chev 216 in it instead of a 228 GM and 4 speed trans. Thanks Murray
First time I saw this truck I said "That's the one!"
1954 Canadian-built Chev Short Box
my 46 1/2 ton is a closed driveline.
I found it easier to pull the engine unbolting it from the trans and taking it out with the bellhousing attached, a lot easier to get the clutch,flywheel and bellhousing off while its hanging on the hoist.
You can always pull the trans afterwards and bolt it onto the engine when it comes time to put it back in, if you don't like struggling to get the input shaft lined up if your by yourself.
1946 Chevy 1/2-Ton
More pix on Photobucket
Sometimes I forget where I left myself....
