2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 8 New Guy | | New Guy Joined: Feb 2011 Posts: 8 | hello i have a 54 3100 4 on the floor i want to add reverse lights does any one know a cheap easy way to do it
thanks
| | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | Just a suggestion, install light run to toggle at dash. | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | Yup, thats what I did. Cheap and fast. Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | That's the way the early vehicles were wired, a separate switch.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | omegaone1954...hope you dont mind me jumping in here.
I was just curious where, on the AD trucks are the guys who add reverse light mounting them? under bed... stake side? What size/type fixture are being used? Anybody have a pic?
I would like to add them on my 50 also. Backing up in the desert the other night made me realize this would be a good Idea.
Toggle switch would work for me, with indicator light.
Thanks | | | | | Joined: Feb 2011 Posts: 8 New Guy | | New Guy Joined: Feb 2011 Posts: 8 | thanks toggle switch will work, not a prob i'm going to hide mine under the roll pan | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | 4 speed should have a seperate shift rod for reverse. What about mounting a pushbutton switch to where it tripped when the reverse shift rod tripped it when in reverse position. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Hi Dads50. I have used backup lights from a early 50s chevy. I made plates and mounted them on the rear bed pocket. I liked them. They lit up behind the truck.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Actually, there was a backup switch available for the SM420 in 1955 on the 2nd Series trucks. It consisted of a collar with a tab for the switch that mounts to the shift tower, then a cast aluminum peice the mounts to the shifter to activate the switch. It is all external of the transmission. The same swithc was also used with the 3 speed manuals, as well as the Hydramatics. If I can remember where i put the instruction sheet that came with the NOS backup lamp kit I used on mine, I'll scan it and post.
Bill Burmeister | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thanks
Ill look around for a fixture. maybe a 4inch would work. | | | | | Joined: Jun 2009 Posts: 789 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 789 | I mounted a set of chrome Guide B-31 backup lights w/ brackets on the rear bumper brackets. A fellow Stovebolter sold me a nice set of lights! I ran wire along the frame into engine bay, then in behind dashboard. Bought + installed a vintage illuminated light switch. I'd share pictures, but have yet learned how to do that here. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I mounted a set of chrome Guide B-31 backup lights w/ brackets on the rear bumper brackets. I would like to see a pic of that set up. I have my spare under the bed. Thanks | | | | | Joined: Jun 2009 Posts: 789 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 789 | sent you pm--do not know how to post pictures to the Forum | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | sent you pm--do not know how to post pictures to the Forum Check the IT Short Bus forum. There are a couple of stickies there to guide you. They are at the top of the threads in the forum.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Bill I'd really like to see a scan of those instructions.
Denny G
Denny G Sandwich, IL
| | | | | Joined: Nov 2008 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 153 | I was fortunate enough to have a spare 4-speed trans., with the reverse switch set up attached. I want to put it on my truck, but the depression switch is bad. Can't seem to find a replacement so far, that is affordable. | | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | Tiny, Thats a sweet ride hence the name Sweetie | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Thank you. The bank account is considerably smaller now.
