There are three small countersink Phillips-head screws along the front of the door, adjacent to the wing window. There are also two below the window regulator, behind the inner door panel. With the window rolled down, the vent window can be pulled upward & inward, to remove. It will need to be twisted 90 degrees, in order to clear the width of the window opening.
