1 members (Samantha), 45 guests, and 4 robots.
Topics128,179
Posts1,057,159
Members48,465
Apprentice
Apprentice
I'm using 1955 GMC cab w/ gauges hooked up to a 1971 chev wiring setup utilizing an internal regulator alt.
My understanding is the temp and fuel gauges are set up with one wire going to a switched 12v and the other to the sending units. Is this correct? thanks Doug
That is correct. The sending units act as variable grounds.
Apprentice
Apprentice
:)thanks Cletis and of course to ck it one would take the wire going to the sending unit and touch it to grnd and the gauge should peg right????
Correct
Apprentice
Apprentice
thank you Cletis I appreciate the help. Not sure why they are not moving to the right as there is power to them yet touching the sender wire to grnd did nothing. Can you tell me which post is the 12v and which is the sending post looking it from the back. Doug
