| | | Forums66 Topics128,188 Posts1,057,216 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 8 New Guy | | New Guy Joined: Feb 2011 Posts: 8 | hello i just got my 54 3100 Yesterday checking it i found the oil level low in the air filter removed it and clean it found a few small holes on the bottom pan i seen a post that some people modified them to regular paper media.do i repair,mod or replace? http://inlinethumb49.webshots.com/29040/2499337980107016920S600x600Q85.jpg<a href="http://rides.webshots.com/photo/2499337980107016920ZSFqac"><img src="http://inlinethumb49.webshots.com/29040/2499337980107016920S600x600Q85.jpg" alt="DSCF3793"></a> thanks
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If I was worried about that I would weld it up. I took the guts out of mine and put a paper element in it. | | | | | Joined: Feb 2011 Posts: 8 New Guy | | New Guy Joined: Feb 2011 Posts: 8 | | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Putting a paper element in place isn't any type of upgrade. If your housing has holes, they need to be filled weather you are using oil or paper. The oil bath is a very good filter. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Putting a paper element in place isn't any type of upgrade. If your housing has holes, they need to be filled weather you are using oil or paper. The oil bath is a very good filter. | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | I like the oil bath, but I finally had enough of the oily mess mine always made. My '67 has the offset style with a separate stand, bolted to the pass side of the head and two wing nuts on top. There is a big rubber gasket inside about 10" x 3/8" x 3/16" thick, that was torn. I tried making a gasket out of various materials and using different solicon and caulk, but it still leaked. I welded a piece of tubing over the hole in the center to act as a dam. The rod for the wing nut passed up through the tubing. I tried it with the oil half way up to the mark, but it sloshed around too much even with heavy oil. The things I did to it reduced the mess, but eventually the bottom of the air cleaner and the valve cover would get oily again. I finally gutted it and put in a paper filter. It is now dry and staying that way. There is no way I would use a oily K&N mess now that it is dry. This air cleaner has the outer sides that come down over the sides of the lower half. Now that there is no oil, I cut large holes to get the air in easier. They are just barely concealed by the outer cover.
'67 GMC 3/4 292 4spd
