7 members (TexasJim50, DadsFirstPickup, 54farmtruck, Patharr, klhansen, Pete1946, 1955 1 Series), 114 guests, and 4 robots.
Topics128,148
Posts1,056,811
Members48,454
I just put new king pins and bushings in the 1948 3600. When I greased them with a grease gun, the caps leaked and one cap came off/out! Yes, I staked each location in four places! I followed the procedures outlined in an orginal 48-53 GM shop manual reguarding king pin replacement.
Do these always leak? Is there a way to seal them and not have the caps come off?
Thank you.
That can be a real problem. When they are installed that should be struck in the center to spread them. Maybe with clean metal, Loctite might help.
1951 1 Ton Completed
Riding in the Passing Lane
Some leakeage will happen. As long as grease comes out next to the axle or thrust brg. it is OK. Like Nix says, hit the plug in the center to expand it. The weight should always be off the wheels when you grease them.
1972 Chevy c10 Cheyenne Super
Thanks for the posts. I punched these in the center to "set" them. I do not like this style/method. I'm in the process of ivestigating the possibility of putting a threaded cap on the ends to seal these. If anyone has done this I would like to hear from you.
Thanks!
