5 members (MRMEROTH11, moparguy, Oswald, Hotrod Lincoln, Otto Skorzeny), 91 guests, and 7 robots.
Topics128,193
Posts1,057,241
Members48,465
anyone has them? what brand is a good one??
I use nothing but Spicer. It could be a 1260, a 1310 or a 1350. Measure the overall length of the trunion. A 1260 is 2 21/32", a 1310 is 3" and a 1350 is 3 5/8/".
I think mine was a 1310-it even fit when I swapped in the mid 70's GM 4X4 rear end.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
I think its a 1310 , i took the caps of and measured the trunion comes out to 3inch.. also the U-Joint has numbers on them SPR F1 89N ZZ, or its SPR F1 N68 22, end caps are stamped Spicer P051
does anyone knows if Spicer 1310 is the same as Spicer 5-153X??
this truck is a total mystery...When i got this bad boy under the hood already had a 283 with a 4speed , 3 Universal joints with a center support..Im sure its not original also.
keepen me on my feet for sure tracing what parts came from what car/truck!
Looks like a Spicer 5-153X is the correct one.
