| | | Forums66 Topics128,268 Posts1,058,378 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | Will a car visor from say 49 to 53 fit a chevy 3100 truck?
Thanks Joe | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | A Fulton exterior visor? An interior visor? A bit more detail will help.
| | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | A Fulton can be made to fit a wide range of body styles. They are adjustable for width. The end brackets came in two styles that I'm familiar with and both will work on most bodies. The main determiner that I'm aware of is the center support. If a visor is made to fit a vehicle with a split windshield it likely won't work on a vehicle without a split windshield since part of the structural support are the two center supports that clamp to the windshield divider. If someone here has made one work I'm sure they'll chime in with how they did it. Fulton instructions.
| | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | The visor isn't a fulton but the guy I talked to said it is adjustable but it has no mounting brackets. Is a 100 a good price for this? | | | | | Joined: Nov 2001 Posts: 1,523 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,523 | It really depends on the kind of visor. If it were a Fulton(which its not) 100.00 would probably be a good price,depending on how much bracketry it needed. On other visors, , some of the mounting brackets can be hand made,depending on how good you are working with your hands and bending/forming sheet metal or stainless steel sheet metal. Maybe by the time you get done making the brackets,or having them made,youd be better off spending the extra 150-200 and getting something complete and ready to bolt on. PICTURES,,PICTURES,,PICTURES. Lets see what youre considering buying. | | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | Thanks for the info, I think I'll hold out for a complete visor with all the brackets. | | | | | Joined: Nov 2001 Posts: 1,523 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,523 | Smart move,,check e-bay for a complete Fulton. | | | | | Joined: Dec 2008 Posts: 53 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 53 | Question for you visor gurus - Were Fulton visors made of steel , fiberglass, aluminum, or all of the above depending on which model? Which would be the best for 50 Chevy Pickup application? Thanks and sorry to piggy back topic. Jerry | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Im not a visor guru I use to have one on my 50 ...pic... It is steel, adjustable, aftermarket, no fulton markings on the end buttons. I still have it. I like the look and may put it back on. Kind hard to see the traffic lights with them. They sell a dash mount reflector to help with that. Good Luck | | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | Dads50 Thats what I'm looking for. It doesnt' have to be a fulton.
Joe
| | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | jremig, I have the exact answer to Your question, Yes, I installed a 49-50 car visor on My truck, but not without some modifications to it...1. I did not use the upper stainless steel molding, plus I removed about 1 inch off the top of visor to allow clearance of roof...2. The roof on the truck has a peak that I extended into the visor...I installed a Fulton visor, then promptly removed it, as it did not appear well because the AD has rounded fenders...This is My opinion only, I just didn't care for the Fulton visor... | | |
