| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#71857 01/18/2007 7:13 AM | Joined: Jan 2007 Posts: 24 Apprentice | | Apprentice Joined: Jan 2007 Posts: 24 | Does anyone know a good locker to put in my c-10? Im going to be putting 3.73's and a locker but I dont know what will be my best choice, also price is very important, the Army doesnt pay that well. I found a local shop that will do the work for $325. Thanks in advance. | | |
#71858 01/18/2007 9:45 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What year C-10? If it's before mid-'65, you'll have to swap axle shafts as the splines are different from the available lockers (17 vs 30). And if it's a '60-'62, you're out of luck with the stock diff. No locker being made for those at this time. Now, if you have the later 12 bolt 30 line, then there's several options. If you're wanting a true locking diff (like a Detroit) I'd suggest either the Lock-Right or Detroits easy-Locker. Both install in the stock case with vrtually no modifications. They're also relatively inexpensive.
Bill Burmeister | | |
#71859 01/21/2007 7:17 AM | Joined: Jan 2007 Posts: 24 Apprentice | | Apprentice Joined: Jan 2007 Posts: 24 | Bill, thanks for the information. My C-10 is a 1964, I think, I know the cab is, alot has been done to this truck before i got it, it used to be a stepside, now its a fleetside, and for some reason it has 66 emblems. Anyways im assuming the axle is a 64. I dont have the 12 bolt its a 10 bolt, I dont know if its a Dana 44 or 60. Do you know where I would get axle shafts from? And roughly how much its going to run me. Thanks again. | | |
#71860 01/21/2007 3:36 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | There is a VIN number on the front framerail, just in front of the crossmember, this will tell you what year your chassis is-although many have had rears swapped etc over 40+ yrs. Eaton lockers are still out there, I just sold one about 2 mos ago. Brian | | |
#71861 01/21/2007 4:26 PM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Perhaps the best locker is made by ARB. They are selectable and not extremely cheap. | | |
