8 members (Bill Hanlon, Waveski, Jon G, Pre '68 Dave, 3B, kades51, 2 invisible),
126
Mod | | | Forums66 Topics128,283 Posts1,058,513 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Does anyone know where to get just the rear brake hose for a 46 1 ton?
Seems it's different than the 1/2 or 3/4 ton. | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | Are you talking about the rubber hose or the metal line?
If you are talking about the rubber hose NAPA should be able to match it up with their stock parts. | | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | On my 51 1 Ton, the rubber hose was supposed to be special. I found the new hose just a tad short. I just bent the metal standoff down a little and the new hose was fine. It didn't matter to me because I was making up all new steel brake lines. | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | I did find one at Napa today. $14, what a deal | | |
