Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (tclederman, rfs56trk, Woogeroo, Peggy M, 1 invisible), 48 guests, and 6 robots.
Topics128,010
Posts1,055,299
Members48,419
#718352 02/05/2011 6:21 AM
Will a car visor from say 49 to 53 fit a chevy 3100 truck?
Joe
jremig #718416 02/05/2011 3:59 PM
Ex Hall Monitor
Ex Hall Monitor
A Fulton exterior visor? An interior visor? A bit more detail will help.
Tiny #718459 02/05/2011 5:49 PM
Sorry outside visor
jremig #718488 02/05/2011 7:10 PM
Ex Hall Monitor
Ex Hall Monitor
A Fulton can be made to fit a wide range of body styles. They are adjustable for width. The end brackets came in two styles that I'm familiar with and both will work on most bodies. The main determiner that I'm aware of is the center support. If a visor is made to fit a vehicle with a split windshield it likely won't work on a vehicle without a split windshield since part of the structural support are the two center supports that clamp to the windshield divider. If someone here has made one work I'm sure they'll chime in with how they did it. Fulton instructions.
Tiny #718601 02/06/2011 2:31 AM
The visor isn't a fulton but the guy I talked to said it is adjustable but it has no mounting brackets. Is a 100 a good price for this?
jremig #718620 02/06/2011 4:07 AM
mine is a Fulton. As you can see in the center, it had to be adjusted to fit the truck
http://i295.photobucket.com/albums/mm128/lt1bubble/a5d799b5.jpg
51_bombtruk #718628 02/06/2011 4:45 AM
It really depends on the kind of visor. If it were a Fulton(which its not) 100.00 would probably be a good price,depending on how much bracketry it needed.
On other visors, , some of the mounting brackets can be hand made,depending on how good you are working with your hands and bending/forming sheet metal or stainless steel sheet metal. Maybe by the time you get done making the brackets,or having them made,youd be better off spending the extra 150-200 and getting something complete and ready to bolt on.
PICTURES,,PICTURES,,PICTURES. Lets see what youre considering buying.
delux54panel #718734 02/06/2011 6:07 PM
Thanks for the info, I think I'll hold out for a complete visor with all the brackets.
jremig #718780 02/06/2011 9:43 PM
Smart move,,check e-bay for a complete Fulton.
delux54panel #718877 02/07/2011 3:34 AM
Question for you visor gurus - Were Fulton visors made of steel , fiberglass, aluminum, or all of the above depending on which model? Which would be the best for 50 Chevy Pickup application? Thanks and sorry to piggy back topic. Jerry
Jerry M. #719178 02/08/2011 4:21 AM
Im not a visor guru
I use to have one on my 50
...pic...
It is steel, adjustable, aftermarket, no fulton markings on the end buttons.
I still have it. I like the look and may put it back on.
Kind hard to see the traffic lights with them. They sell a dash mount reflector to help with that.
Good Luck
DADS50 #719181 02/08/2011 4:27 AM
Dads50 Thats what I'm looking for. It doesnt' have to be a fulton.
Joe
Jerry M. #719201 02/08/2011 5:32 AM
jremig, I have the exact answer to Your question, Yes, I installed a 49-50 car visor on My truck, but not without some
modifications to it...1. I did not use the upper stainless steel
molding, plus I removed about 1 inch off the top of visor to allow
clearance of roof...2. The roof on the truck has a peak that I extended into the visor...I installed a Fulton visor, then promptly
removed it, as it did not appear well because the AD has rounded
fenders...This is My opinion only, I just didn't care for the Fulton visor...
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
