0 members (),
91
Mod | | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 41 | Hi All,
I thought I'd put this question in the bigbolts section since hydroboosters usually are only found on 1 ton and bigger trucks.
I have been searching autozone earlier and noticed that they carry 2 different hydroboosters for our trucks. The part numbers are 51-8028 and 51-8062. They label them as 51-8028 being a hydrobooster with master cylinder hydrovac and 51-8062 as hydrobooster without master cylinder hydrovac.
My question is, what exactly is the difference if anone knows? I'm assuming one has an extra feature and the other doesn't, but I'm not sure. If there is a difference in operation, does anybody know the pros and cons?
I'm sure somebody on here will know, Thanks, 54Monster
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | So are you trying to add a booster or replace an existing hydrovac. If you want to replace an existing hydrovac, I would go to someone who knows something about them. I would not consider Autozone as someone who would know anything about almost 60 year old brakes. | | | | | Joined: May 2007 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 41 | I appreciate your response. I have a working unit under my 2ton. I was just noticing that there seems to be 2 different types being offered and was wondering what the differences between the 2 units are, if any.
Thanks, 54Monster | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy guys, this may just be a terminology thing, but a hydrobooster is a booster that uses hydraulic pressure from a power steering pump to accomplish the boost. The hydrovac uses engine created vacuum to provide the boost. 54Monster, please remember to tell us what year and size of truck you're asking questions about, I assume it's a 54 | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Bendix made several different part numbers of the same basic hydrovac. They will work in the place of each other, but will require plumbing changes. It is much easier to identify the one you have and replace like for like. If yours is working, I wouldn't worry about it. | | |
