Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (3800GUY, baldeagle, Wayne67vert), 42 guests, and 3 robots.
Topics128,005
Posts1,055,266
Members48,418
#71827 01/17/2007 5:05 AM
There's a great Tech Tip on this board on HOW to replace king pins but my question is: how do you know WHEN they need to be replaced? Is it the same basic check for loose wheelbearings, i.e. wiggle the hub up and down and check for play?
#71828 01/17/2007 5:14 AM
Loose Kingpins will allow some movement up and down. Jack up the axle, but leave the tire close to the ground. Have a helper pry the wheel up with a pry bar (just enough to make it move, not compress the spring) and watch the spindle/axle point. There should be no movement between the two.
#71829 01/17/2007 9:49 PM
Riding in the Passing Lane
If the backing plate moves when you pull the wheel in & out it,s the king pins. If just the wheel & drum move it,s the wheel brgs. You can snug up the spindle nut to get a better feel.
1972 Chevy c10 Cheyenne Super
#71830 01/17/2007 11:30 PM
You should not be able to detect any side to side play in the kingpins. the thrust bearing between the spindle and the axle can have up to .005" clearance.
1951 1 Ton Completed
#71831 01/20/2007 10:43 AM
Also check your spring eye bushings and shackles for wear. If the king pins are worn out so are the bushings. They have almost the same effect as worn king pins but are harder to check by hand.
Paint & Body Shop moderator
