1 members (klhansen),
147
0
Mod | | | Forums66 Topics128,162 Posts1,056,939 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | Hello - looking for opinions on the safety of running tube type bias tires on the front of a 58 Chevy 2.5 ton (Dayton wheels). The rears are all tube type in very good shape. I've got the tires, flaps and lock-ring wheels for the front, just would buy new tubes.....but I have this hesitation, believing that a tube-type blowout would be more likely and more catastrophic than a tubeless flat. Thoughts on this?
1955 GMC 630, 1959 GMC W660, 1958 Chevy Spartan 80
| | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | I've been running my bias plys on my 55 2 ton with loads down the hiways without problems. I think the tube tires are tougher for the stumps I occasionally run over. I think a blowout is a blowout when it comes to tires. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I like tubeless tires, but there is nothing wrong with tube required tires. The most common cause of flats is folds in the tube caused by over inflating a tube when looking for a leak. Back when we ran tube required tires, we always put in a size smaller tube. Such as a 9.00 tube in a 10.00 tire. However, since you have Dayton wheels, finding tubeless wheels wouldn't be too difficult. In fact they are still produced. | | |
