| | | Forums66 Topics128,105 Posts1,056,208 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 30 New Guy | | New Guy Joined: May 2010 Posts: 30 | This is for my '59.... I'm in the process of trying to remove my front original leaf springs. I can remove the most rearward shackle bolt as I just punched it out after removing the 15/16"nut. I was able to remove the two 3/4" nuts off the front shackle bolt which left me with a dual threaded bolt still sitting in my spring eye. Maybe this pic will help http://i1040.photobucket.com/albums/b403/cwc1965/Apache/shackle.jpgIs the front Shackle the "pivot end of spring" as called out in the manual?(section 3-5) Is anything threaded in there or can I just wack it out. Doesn't seem to want to move at this point. Want to make sure it is not threaded in there. Thanks, Chuck | | | | | Joined: Jan 2011 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 85 | http://www.chevsofthe40s.com/detail/10563/Chevrolet_BOLT_BUSHING_FRONT_OF_REAR_SPRING_FOR_TON.htmlis what it is. You shoudl be able to hammer away. The bolt is hollow though, i suspect they are pretty hefty but i would still use caution if you intend to use that bolt again. i'd personally put the nut on the end again just till it covers the end threads and then whack it. prevents some disfiguring of the bolt and causing more issues trying to get it out.
52 Chevy 1/2 ton - work in progress 65 Mustang coupe - work not in progress  67 Mustang GT convertibile 67 Camaro RS/SS We are now even with fords and chevys. Now i need a mopar. Hahahahahahahahaha
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You will have to take all the nuts off. Then jack up the axle till it relaxes & tap the shackles off. Then the pin can be screwed out or it might slide out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2010 Posts: 30 New Guy | | New Guy Joined: May 2010 Posts: 30 | "Then the pin can be screwed out or it might slide out."
That is what I am trying to ask here. I don't want to keep bangin' on it if it is threaded
The axle is already out.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | On Task Force trucks, the shackle pins are threaded. Since yours has nuts on them, they have been replaced. The originals did not have nuts on them.
Bill Burmeister | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I was going by your photo. You will have to remove the rest of the nuts to get the spring off. Like Box55 says the pin screws into the bushing. I believe the pins with the nuts on them came on 58-59 models. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2010 Posts: 30 New Guy | | New Guy Joined: May 2010 Posts: 30 | Gotcha, the side panels to the shackle must not be threaded. let me go out to the garage and give it a go. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The side plates have tapered holse where the pins come through, similar to a ball joint or tire rod where they mount into the knuckle. You may have to give them a good whack to get them off, but the shoudln't be too hard. Then the pin should come out easily. Wrenchbender, I just checked the manuals, seem the change was was '57 to the pins with the nuts.
Bill Burmeister | | | | | Joined: May 2010 Posts: 30 New Guy | | New Guy Joined: May 2010 Posts: 30 | It's out.....thanks all...stay tuned as I'm sure more questions will arise during my swap....now for the passenger side. | | | | | Joined: Oct 2010 Posts: 33 Geezer | | Geezer Joined: Oct 2010 Posts: 33 | I do not know if this helps, but here is the NAPA part number for a shackle kit,
NCP 2741766 $43.49
I am going to do this to mine also,
thanks for the info,
TC
1966 C20 LWB, 327 4 Bbl., 4 Speed
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | So were they threaded inside or not? | | | | | Joined: May 2010 Posts: 30 New Guy | | New Guy Joined: May 2010 Posts: 30 | They were indeed threaded. Albeit not a tight thread. I was able to unscrew the pin from the bushing with my fingers. Let me have my coffee, wake up a bit and I'll take a picture a post it. | | | | | Joined: May 2010 Posts: 30 New Guy | | New Guy Joined: May 2010 Posts: 30 | | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I see they didn't provide the bolt that goes through the middle. I found the same thing when I did mine. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | From what I saw in the manuals, the bolt was eliminated when they changed the design in '57 to having nuts on the pins. When I did mine, I put new bolts in them anyway. BTW, the threads are not supposed to be real tight on the pins, as that type thread is more about load bearing surface area rather than retantion. That thread is called an Acme thread.
Bill Burmeister | | | | | Joined: May 2010 Posts: 30 New Guy | | New Guy Joined: May 2010 Posts: 30 | Excellent....I figured it was loose by design...now I know the name for it....probably forget it by tomorrow morning however. | | | | | Joined: May 2010 Posts: 30 New Guy | | New Guy Joined: May 2010 Posts: 30 | Rather than starting a new thread....I have another question regarding spring retention. I notice that both of the rearward spring eye bolts for the front springs were bent when I pulled them out. Common occurrence on 52 year trucks? or by design? | | |
