Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (thekid1950, baldeagle, Steelonsteel, cmayna, Rusty Rod, 78buckshot), 50 guests, and 2 robots.
Topics128,006
Posts1,055,268
Members48,418
#718085 02/04/2011 2:55 PM
I have this door, that required, that the bottom of the door be repaired. When I put the new outer piece on, it developed a dip about an 1/8" deep, and approximately 4 inches in diameter. I used a puller to pull it level, the variety with the copper studs. When, I do pull it as soon as the pressure is released the panel goes back to the wrong position. What is the proper method for keeping it flat? I can not get to the back side of the panel. The new panel is the full width of the door and 11" tall. I can put enough pressure on the panel to move it past level, but is that the correct method, as it will then be bowed up. I do not want to that much filling with filler.
GMCAMARO #718171 02/04/2011 7:58 PM
What it was was the natural shape of the metal wanted to go down from the pressing at the factory. What I did was cut a "T" in the lowest point when I had in the correct position. The welded the "T" closed problem solved.
