0 members (),
119
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | I probably should post this in interiors forum but you guys are so responsive I thought I'd just post it here.
I have two broken springs on my bench seat that I am redoing. One spring is the corner spring at the front of the bottom seat. You know, where you get in/out all of the time. The other is also on the bottom and is one of the long pieces of metal with a small coil on the end. Any recommondations?
a
Tom 1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
| | | | | Joined: Jan 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2002 Posts: 59 | Hello A company called Auveco used to make and sell these springs. I'm not sure if they're even still in business. I have seen Nos ones show up on ebay from time to time . Your best bet would be to find an upholstery shop thats been around a long time and ask them. | | | | | Joined: May 2009 Posts: 47 New Guy | | New Guy Joined: May 2009 Posts: 47 | I just did my seat springs a couple winters ago. I went to an upholstery shop and ordered a roll of s spring , they use it in couches and it works great. Just cut what you need and fit looks just like the original | | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | Pictures would be a big help, I just did a 66 gmc pickup seat and it is completely different that the springs in a 65 chevrolet that I have. post the pics give dimensions I found obsolete inventory at American Upholstery in Tulsa, Oklahoma. I just went over and looked through 100 boxes of obsolete springg and bought what I needed (10 -12 springs) Send me one original spring of each type and I will go over there and find what you need. (do the pictures first so I can look before you send them to me) Kieth Tulsa, OKlahoma 918-446-2245 e mail pictures to [email protected] here are pictures of my 66 gmc seat, http://kieth.smugmug.com/Trucks/66-GMC/13311086_gRF57#989634304_xhcKpdoes your truck seat look like mine ?
66 GMC SWB 65 Chevy LWB 65 GMC SWB
918-446-2245
| | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | If you have a salvage yard you can go to, you can pull one from the passenger side (I believe that they are mirror images left to right) of the seat and use that to replace what you need.
| | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Kieth,
My seat looks EXACTLY like yours! I have two broken springs on the bottom seat. One is the long piece with the little coil on the end just like yours. The other one is the corner spring that is bent 90-degrees or so in the corner bottom. I'll go take pictures and send them to you. That would be so awesome!
Thanks!
Tom
