0 members (),
38
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 66 | Is there a trick to getting the top door hinges through the small opening in the door frame? I am having trouble getting them through. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I can relate, I know with the "check" springs in I beleive it helps if the hinge is in the open postion. No matter it still a tight fit. You sure hate to do it after you've painted everything! | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I used a deburring tool and took a little off the edges mine slip in and out easily and you can't see the difference. If you don't and you paint then later have to pull them they are going to damage the paint. | | | | | Joined: Mar 2007 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 66 | I opened the hinge all the way and was able to wiggle it through the opening. It doesn't quite fit, but it went through. Thanks for all your help. | | |
