5 members (52Carl, GradyB, GRNHydra, Pre '68 Dave, DadsFirstPickup), 82 guests, and 1 robot.
Topics128,080
Posts1,055,944
Members48,430
#717459 02/02/2011 5:44 AM
Has anyone around here that has experience in re-clipping a 53 3100 know if a 87 monte carlo clip will work? I know a guy that used an 82 Monte carlo clip but are they the same?
anyone..?
p.s. I don't care about "taking the truck out of the truck" and all that argument. This truck will never haul again.
*UNDER CONSTRUCTION*
1953 Chevrolet 3100 1/2 ton-previously abandoned resto.
My Project Bolt
I hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
I haven't used one but an 87 is the same as an 83 IIRC.
Those have the steering box mounted up front. Measure to make sure it's not too far forward or you'll have a challenge getting all the nose sheet metal to fit without extensive fabrication. You'll have to alter the radiator core support, the lower splash pan, and inner fenders. For example an S-10 frame has the steering box several inches forward of a Camaro '70-'81 subframe. Basically you can make anything fit, it just depends on your abilities and finances.
Hey Siverado_9c3, By the way did you get my PM about Lynn?
I used a Monte Carlo clip on my 55 2nd series. The frame is the same from 1978 to 1988, with only 1978 and 1979 using some different front wheel bearing and stud combinations if I remember right. I used the Monte because the track width is great for keeping the front wheels tucked inside the front fenders without having to use weird offset front wheels. It is 58.5", and I think the S10 is 54.5". I think all of the Camaro and Nova clips are around 60-61".
wbrowne..yes I did sorry I did not respond, Its been a long week.
Oleblue55- What year MC Clip did you use?
My Project Bolt
Wbrowne is right about the steering box being to far forward,I took alook at the monte carlo but chose the camaro instead.You can reuse the rad mounting bracket from your truck and adapt it to the clip with some 1/8 x 3 flatbar. If you like send me a PM and i will send you a few pic's
layback
