9 members (MickeyP, TexasJim50, MRMEROTH11, 2-Ton, Southerntruck, Ponchogl, JW51, Shaffer's1950, 1 invisible), 117 guests, and 2 robots.
Topics128,132
Posts1,056,378
Members48,441
Does anybody have any pictures on a 216 motor with a double or triple Carburetor setup? I was on a couple of days ago and a guy had some great pictures of his setup...I can't remember where I was....I was just doing my homework before I get started...
1951 3100
http://community.webshots.com/user/HolcombRacing11
"Every child is an artist. The problem is how to remain an artist once he grows up."
Pablo Picasso
You can click on the link below to see a set-up I just finished for my 235. I moved the 2 outboard carbs in a little for clearance. Check the firewall clearance carefully, if you get an Offy manifold the carb flange is directly in line with the intake port so make sure it will work. I had to modify the fender brace to go around the carb on my '53. Have fun!
How does it run...Do you get more horsepower out of it...Gas mileage..does it eat alot..I noticed your choke is connected to the middle one...what about your throttle cable? My 51 looks like yours but a little lower to ground....and not a 5 window
1951 3100
Pablo Picasso
Forgot where did you get your air cleaners at? and carb set up at? I'm thinking about doing a double? I like your triple but one less carb to buy.
1951 3100
Pablo Picasso
Holcomb; got the carbs from e-bay, the air cleaners from Chev's of the 40's. Right now I've got the outboard carbs blocked, only running on the center, so - gas mileage is good! Throttle linkage is stock and I built a linkage so that all carbs open at the same time. Whole set-up cost less than $100 but I haven't rebuilt the other 2 carbs yet.
My truck sits a little lower front and rear than the pictures show.
Thankyou for that...I will look into those air cleaners when it get closer...mine sits low...due to the fact that the guy took out leafs and heated them up....for a long time my rear sat on the frame...which is pretty low...I have air shocks in the back which gave me 2 1/2 inches of room...at least its not sitting on the frame anymore.
1951 3100
Pablo Picasso
