4 members (Hotrod Lincoln, BC59, 2 invisible),
134
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 47 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 47 | hi guys. i'm installing the glove box door and can't get it to completely shut and engage the latch. i'm working on a 1950 chevy 1/2 ton. i bought and installed the lock/hook mechanism from Classic Parts. the latch on the door hits the hook but the hook does not go down and under the door latch. i assume that's what it's suppose to do. i've tried adjusting the door latch but no luck so far and i'm afraid of breaking it off. how is the hook supposed to engage the door and hold it shut. thanks.
Che 1950 Chevy 3100
| | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | Did you unlock the push button with the key, also if you installed a cardboard liner for the glove box make sure the gap for the latch is in the right place.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
