1 members (Otto Skorzeny), 81 guests, and 2 robots.
Topics128,034
Posts1,055,547
Members48,425
#716076 01/28/2011 7:18 PM
hello need some help 50 chevy 216 motor,its 6 volt it has 8 volt battery,it has a bad drain every time i drive it the battery goes?
ptony #716106 01/28/2011 9:16 PM
H Online: Content
An 8 volt battery is a solution to a nonexistent problem. Get the 6 volt system cleaned up and working right, and donate that 8 volt battery to somebody's recycling bin. It's necessary to adjust the charging voltage to 9.5 volts to keep an 8 volt battery charged, plus adjusting the cutout relay to 8.5 volts to keep the regulator from connecting the generator to the battery too soon. Anybody with enough understanding of a DC charging system to make an 8 volt system work knows better than to try it in the first place.
thanks,
ptony #716929 01/31/2011 7:23 PM
MLT Offline
Yep. This is the first thing I fixed when I got my 51. I had an 8v battery too She's all correct 6v now and works as originally intended. How's your wiring?
