0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 2 New Guy | | New Guy Joined: Jan 2011 Posts: 2 | hello need some help 50 chevy 216 motor,its 6 volt it has 8 volt battery,it has a bad drain every time i drive it the battery goes? | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | An 8 volt battery is a solution to a nonexistent problem. Get the 6 volt system cleaned up and working right, and donate that 8 volt battery to somebody's recycling bin. It's necessary to adjust the charging voltage to 9.5 volts to keep an 8 volt battery charged, plus adjusting the cutout relay to 8.5 volts to keep the regulator from connecting the generator to the battery too soon. Anybody with enough understanding of a DC charging system to make an 8 volt system work knows better than to try it in the first place. Jerry
| | | | | Joined: Jan 2011 Posts: 2 New Guy | | New Guy Joined: Jan 2011 Posts: 2 | | | | | | Joined: Nov 2010 Posts: 63 New Guy | | New Guy Joined: Nov 2010 Posts: 63 | Yep. This is the first thing I fixed when I got my 51. I had an 8v battery too She's all correct 6v now and works as originally intended. How's your wiring? | | |
