7 members (Philipj, CharlieF, CATMAN, klhansen, fonz8261, Shade Baby, Phak1),
84
Mod | | | Forums66 Topics128,153 Posts1,056,842 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | I soon hope to install seatbelts (lap only) in my 41 1/2 ton. Does anybody have any good pictures of where they attached theirs to the cab? Thanks
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Sorry....no pics. Mine are mounted thru the floor panels with big washers washers each side to spread the load. | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I put a piece of 1/8" steel plate between the washers and the floor on mine. I used the washers that came with the belts. Sorry, I can't get any pictures right now either.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Jan 2011 Posts: 90 New Guy | | New Guy Joined: Jan 2011 Posts: 90 | Hi what you need is too mount them basically as far back and as high up as you can on the main floor pan so any force that gets trasmitted to them is a more sideways force or as low an angle as you can, Ideally mount them in the floor through as solid and thickest part of the floor you can. In the Cars I worked on ( Rangerovers Bmw's The new Mini, Rovers, Some Hondas and some Nissans, I was a Engineer in charge of Reworking any assemblies that didnt meet standards back too Engineering specs) we had a plate nearly an 1/8 thick and sometimes 3" by 2" Square that was spot welded inside another Assembly then this was mounted again with multiple spot welds too the floor, So basically In the event of some Force it spreads that force over a greater area and wont pull through ( the last thing you want too happen).More modern Seat Belts are mounted that will Peel slowly allowing force too be built gradual. but its a bit precise Engineering For that, My personal approach would be too weld at least a 1/8 inch 3" by 3" too Either the head of the bolt and mount it With bolt going inside the cab then Either a larger plate or washers on the inside under the seat belt, Or weld a 3" By 3" plate inside too the floor (Less desirable) . All you are trying too do is spread the load over a greater distance and prevent them from pulling through the floor. On A personal Note I hope what ever way you mount them That you never ever need them Ryan
1954 3600 With 1950's Powers of St Louis Utility Bed. My truck | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Make sure the seat is anchored well, you don't want the seat belt to be taking the load of you and the complete seat assembly together. Also work out a way to use a shoulder belt too, even with lap belts your going to whack that non-collapsing steering column and the header panel over the windshield pretty hard if you do have an accident. Also if you are having kids ride in the truck definitely use shoulder belts, there have been terribly severe spinal injuries to children who have only had a lap belt on, as they tend to buckle over in a crash damaging their lower spines, because they aren't tall enough to hit the dash, this is why you don't see lap belts in the back seat any more. | | |
