| | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 111 | Does anyone know if it is possible on a 1946 Chevy 1/2 ton to attach a pre-assembled front end to the truck or should I try to put it on piece by piece( fenders first then the rest)?? It seems almost impossible to align the fenders, 2 pc. grill, inner panels, filler pieces, lower valance and everything else if putting it together one at a time since there are dozens of screws and bolts. thanks mh
54 Chevy 5 window - 46 Chevy 1/2 ton
| | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | I believe you can (attached pre-assemble front clip) tho I've never done it. Others on here may know more. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Not sure with the '46. On my '40, I assembled in pieces. Would be pretty difficult to mount entire assembly without marking paint I would think. With mine, I assembled radiator / cowl first, then fenders, then top hood, side hoods. Grille went in last. | | |
