1 members (carbking),
103
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 11 New Guy | | New Guy Joined: Oct 2010 Posts: 11 | Can anyone advise me on the trick to removing the drive shaft from the engine on a 1.5 ton chassis. I am having problems with the u joints. According to the manual there are cap screws that need to be removed. My truck does not seem to have these at either the front or mid u joint? The ball joint only seems to move back 2+" Any help would be greatly appreciated. Thanks | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | It could possibly have snap rings holding the cups if it doesn't have cap screws. If you drop the center bearing support, it will give you more wiggle room. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy tracermc, welcome, please remember to tell us what year and size of truck you're asking about, lots of different engineering over the years. | | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | I have a '47 1.5 ton. 4 speed box, 20" dual wheels. There is a uni at the back of the gearbox, one behind the centre bearing, and one on the diff pinion. Its a two piece shaft, all exposed, no torque tube. Each uni is held in place with two u bolts in one plane, and fully captive on the other plane. I'm figuring you have something different? I undid the ubolts and it all wiggled off. As Crenwelge said, drop the centre bearing and it should come off.
'47 Canadian RHD 1.5 ton truck
| | | | | Joined: Oct 2010 Posts: 11 New Guy | | New Guy Joined: Oct 2010 Posts: 11 | Sorry about that, it is a 1940 1.5 ton WB series truck. The front u joint has the snap rings holding the bearing cups but the rings can't be reached to undo. The mid carrier u joint does not have snap rings and seems to have a different set up than what the manual describes. Any advise would be greatly apprciated. Thanks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy tracermc, okay if your driveshaft does not have "U" bolts holding the U joints in place, then it probably has a flange system with four studs sticking out from the flange on the transmission output shaft, if you remove the four retaining nuts from the studs you should be able to pry the flange off of the transmission output flange, the center support may have a similar system, good luck, and let us know how you made out. | | |
