4 members (Otto Skorzeny, mk72, 55shaker, 1 invisible), 77 guests, and 1 robot.
Topics128,022
Posts1,055,387
Members48,422
#716332 01/29/2011 6:03 PM
Q
Q Offline
any suggestions on cooling
have a 48 barn find
Michael Salsa
qballhd1 #716345 01/29/2011 7:00 PM
air conditioning?
squeeze #716352 01/29/2011 7:18 PM
Open the windows? Fill the radiator?
Input. Neeeeed mooore iinnnpuuut.
1951 3800
-hotshoe
hotshoe36 #716359 01/29/2011 8:12 PM
dash mounted fan ?
1951 3100 Chevrolet
bowtietim #716361 01/29/2011 8:15 PM
180 degrees is normal for these old trucks, if you want to run cooler, change the thermostat out to a 160 degree unit. Make sure your radiator cap is good and you might want to replace your current water/anti-freeze.
GMONIZ #716457 01/30/2011 3:30 AM
I agree. 1948 was a fantastic year for a truck
Dennis
oldbluetruck #716941 01/31/2011 8:11 PM
Q
Q Offline
thanks I drive stop and go 10 miles to and
from work,stays about 180
but thanks for the tip gonna get an over flow tank
and new upper and lower hoses
Michael Salsa
qballhd1 #716959 01/31/2011 9:11 PM
Have you flushed the coolant system?
Dennis
oldbluetruck #717523 02/02/2011 4:17 PM
Q
Q Offline
no not yet got new cap yesterday also
added royal purple water additive
Michael Salsa
qballhd1 #717524 02/02/2011 4:18 PM
Q
Q Offline
Also got new tires yest.
T/A Radials 245/60/15s
Michael Salsa
qballhd1 #717592 02/02/2011 8:29 PM
I have never heard of royal purple water additive. I will have to google it.
I like to flush with the engine running. I open the lower valve and put the garden hose in the top. Usually, the water goes from nasty color to clear. If it is real bad I will go with a radiator cleaner from the local FLAPS. Drain and flush, then fill with either pure coolant or a 50/50 coolant mixture.
Best of luck
Dennis
qballhd1 #717609 02/02/2011 9:48 PM
To keep the radiator healthy always use distilled water, keeps it form get al the lime and minerals.
54 5-window 3100 #717643 02/02/2011 11:22 PM
Q
Q Offline
looks good n green
Michael Salsa
qballhd1 #717671 02/03/2011 1:03 AM
Leave about 3/4" to 1" head space when filling the radiator.This will keep it from spewing out the overflow.
Good Luck!
Tim
1951 3100 Chevrolet
