0 members (),
188
Mod | | | Forums66 Topics128,089 Posts1,056,441 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | can pick one up for 400. says ran good but smoke was coming out of the draft tube before it was removed from a 62 suburban. are these good motors? better than the 1960 235 i have?? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | http://www.oldchevytrucks.com/Articles/261-Engine.phpThe difference in performance-numbers might not look so impressive. However, the improvement is quite noticeable. For extra oomph, you could adapt your 1960 235s high-compression head as a replacement for the 261's head. | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | thats quite interesting thank you. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | the difference in performance-numbers might not look so impressive. However, the improvement is quite noticeable. just ask the "SWEET"  | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | The 261 will give you a larger 'OOOOO' factor. And bragging rights - that you have one.
It's an engine out of a bus
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | It's worth about 8-9% more power with using higher RPM. Has stronger rods. It's the biggest you can make a stovebolt without shredding the budget. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | a 261 it like a 235 on steroids. Its got that little extra umpf that puts a smile on your face!
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | makes me really wanna pick it up. question though, i wanna purchase the fenton dual headers, offy dual intake, and get the polished side cover and valve cover....will all this still bolt on a 261? | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | just got the blocK# 3769717 and head# 3836850. what is this from? and has head been changed? | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Those are the numbers for a 1959-62 261 engine. It could be original head and block combination. It should also have the flow-through oil filter with 1/2" NPT threads in the block.
Hoyt | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | makes me really wanna pick it up. question though, i wanna purchase the fenton dual headers, offy dual intake, and get the polished side cover and valve cover....will all this still bolt on a 261? As long as those parts are for the later 235 (not the 216). The valve cover might need adapter bolts (if it is a 2-bolt cover), but most reproduction parts vendors sell these bolt kits. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Foster
Yes all those parts will fit. Check out my webshots page......
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | just got the blocK# 3769717 and head# 3836850. what is this from? and has head been changed? The 261 block casting is from 1960-62 and had the front center mount. The 261 head casting was used from 1954-62. From 1954-57 the 261 also used head casting 3703570. There should be some date codes on the block and head.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | thanks for the pix. ill finish looking at it later. just bought the 3;55 gear kit for my 51 too. just waiting on the new bearing kit before i tackle it. your pix will come in handy. ill get pix soon, just been working so much lately. basically my truck is just a powder coated frame sitting in my gargage with boxes of goodies for it, just no time......sad | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | also where did you get your sway bar? thats what im looking for. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | The sway bar was a fun bolt on project. I got the sway bar off eBay, took it all apart, got the bushing kit from Carters, painted, re-assembled, and put it on the truck. Make is drive much better.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | i just junked my entire 260 engine and 3 speed tranny two days ago. got 54 bucks for it.
*UNDER CONSTRUCTION* 1953 Chevrolet 3100 1/2 ton-previously abandoned resto. My Project BoltI hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
