0 members (),
155
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#71604 01/13/2007 5:13 PM | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Hi..I would like to flush out my engine/radiator after doing some heater work is there a removable block plug on a 1955 235 engine that can be removed to get the Gra-doo out and where would I look for it....THANKS, Steve | | |
#71605 01/13/2007 5:33 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | It's on the manifold side just above the oil galley and at the back very close to the bellhousing. If you remove it and nothing comes out get in there with a coat hanger until it flushes clean.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#71606 01/13/2007 5:56 PM | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | HEY...THANKS!...I hope its a threaded part and not a freeze plug? Steve | | |
#71607 01/13/2007 7:16 PM | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 |
cgresham1212 If you don't drive it, why have it? 55 1st Series 3100 5 window
#71608 01/13/2007 11:22 PM | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | THANKS...threaded makes it a whole lot better! Steve | | |
