5 members (latroca52, Woogeroo, Mike Burns, Rusted Nut, TS3600), 68 guests, and 3 robots.
Topics128,188
Posts1,057,334
Members48,469
Hi..I would like to flush out my engine/radiator after doing some heater work is there a removable block plug on a 1955 235 engine that can be removed to get the Gra-doo out and where would I look for it....THANKS, Steve
It's on the manifold side just above the oil galley and at the back very close to the bellhousing. If you remove it and nothing comes out get in there with a coat hanger until it flushes clean.
Curt B.
You Tube
HEY...THANKS!...I hope its a threaded part and not a freeze plug? Steve
Threaded is correct.
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
THANKS...threaded makes it a whole lot better! Steve
