| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 23 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 23 | Have not posted in while have not really had time to work on the truck Im gonna tear the front end down this weekend for king pins and bushings where can I find the pins and bushings no luck at the local auto parts stores its a 57 6500 my next project is gonna be the hydravac I talked to Rick at Reman in Atlanta they have the kits I work in Atlanta so Im just gonna take it by so he can hook me up with the right kit Im losing fluid through it now and leave my park brake shoes for relining Thanks Kip | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Kipparham, the o.e.m. number I came up with is 3691111 that is for a standard duty axle, the pin diameter is 1.1090" X 6.343" long, one lock pin groove. The direct Moog crossover p/n is 8343B, p/n 8490T may work as well. Rock Auto has 8343B for $43.79, hope that helps. | | |
