2 members (1955 1 Series, Donf), 327 guests, and 6 robots.
Topics128,160
Posts1,057,054
Members48,463
wont go into gears-----
R Online: Content
Go back to the basics and check your work. Make sure that the shift rods are installed correctly. You may need to disconnect the shift rods to make sure that you can obtain the neutral position on both shift arms on the trans. Also check to see if the clutch is engaging correctly.
Fred
did you use the correct throw out bearing?
65 Chev shorty
65 Chev longbox
65 Chev crewcab
65 Chev bus!
Photobucket pictures
New clutch??? Disc in backwards maybe!!!
