4 members (Bill Hanlon, J Lucas, Steve_H, 1 invisible), 121 guests, and 5 robots.
Topics128,186
Posts1,057,211
Members48,465
#715697 01/27/2011 3:36 PM
JC
Offline
Hi All,
When I got my 66 c20 project truck from stovebolter Tony Smith back in 2006 (Ol Green) it had a non-running 6 in it. I thought it was a 250, but it turned out to be a 194. I figured someone put it in to get better mpg. At the time I swapped it for a 292 to get the truck on the road and since then I have had 5 motor swaps, a 250, another 292, a 327 and a 350. This Winter I put a 194 back in the truck!
I bought the 194 cheap and the seller said it ran good and had been rebuilt. It was in a 64 Nova wagon. When changing the 194 to a 292's oil pan, I could see the inside of the motor was fresh. For a carb, I put a Rochester Monojet off a 78 292 and for the ignition I added a MSD 5 to the stock setup. Once in the truck I thought the motor would bog down and have little torque and pep. I justified the swap because I only drive a few miles to work each day and was very tired of getting 8mpg from the 350 that was in it. Also, I was curious how the truck would run with a 194 since there was one in it when I bought it.
To my surprise, the 194 does not bog down or sputter, and she smoothly revs quite nicely! After a week and a half I am still on the same tank of gas, so I have not checked the mpg yet. On the highway it keeps up with traffic, no problem (4:10 gearing and 31" rear tires). I guess this swap has been a lesson for me and should reduce my time spent at the gas pumps!
JC in KC
"The future will be better tomorrow." Dan Quayle
1965 Chevy C10 Long Fleetside
I'm sold on inline 6's, I got 29+30 with the original engines the 29 I can balance a nickle on the valve cover when it idals! And I've got a 54 Plymouth flat head six
When I was in high school[like most kids your not as smart as you as you think you are] I had a 1962 Chevy II, 194 standard shift, it would smoke the tires! The only car I ever had that would do it! I could get more rubber in second rear than most car could do in low, run the day lights out of it and use $5 worth of gas a week Then I traded for a 62 Implala Sport Coupe 283 standard shift, cool car but would not get the rubber like the Chevy II and used $15 a week in gas!
