Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (Peggy M, tclederman, 2 invisible), 53 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#71568 01/12/2007 3:48 AM
I need to replace some of the front hub wheel studs (8 lug) on my 3800 series. I know they are 1/2". Does anyone know a part number or how they are identified. My old studs have a "M" stamped on the rear end of the stud. Also, how mich air pressure should it take to seat them into place?
#71569 01/12/2007 4:05 AM
If you find a source for them, please post it. I do see that LMC lists them in the catalog. I don't know what you mean by air pressure but you can seat them with a lug nut and a sleeve or larger nut.
1951 1 Ton Completed
#71570 01/12/2007 4:26 AM
my local NAPA has a rack of all different wheel studs, they've always had any size I needed, just take one to match the base
#71571 01/12/2007 6:57 PM
The best way to remove/install wheel studs is with a hydraulic press. Definitely don't try to pull a new one into place with a lug nut and a stack of washers, or something like that. It might be possible to use an air hammer with a blunted punch to drive one in from the back side, but make sure it isn't trying to displace a lot of metal as it cuts its new splines in the hub. I have had to file a little off the spline of a new stud at times to ease installation a bit. Removing one stud by threading a lug nut on flush with the end, and using a BIG hammer to pound it out usually works, so you can take an example to the parts store, but getting one back in that way can be challenging! I prefer a press!
