4 members (Rick Brown, Bill Hanlon, 2-Ton, 5 Window 9434), 198 guests, and 1 robot.
Topics128,108
Posts1,056,238
Members48,437
#714515 01/23/2011 10:40 PM
Does anyone have a picture of a repaired rear cab support on a 60 apache? I am getting ready to replace my supprot/brace and I would really like to see a picture of a finished one.
Paul
The cab support on the underside of the cab, itself or the frame-to-cab perches, factory riveted to the frame?
The cab support on the underside of the cab. I am going to replace mine this weekend and I need a picture - mine are pretty bad and I am not sure I can figure out placement without a picture.
THanks,
Paul
A patch panel is available for the rear cab support, both full & slip-over. I would stay away from the slip-over, since it is just covering up the problem, in lieu of fixing it. The supports are self-aligning, since they will only fit in one direction and relative to what is removed.
I have the full patch panels ready to go - I just want a picture of what they are supposed to look like when they are finally installed.
Paul
