2 members (Hotrod Lincoln, Millenimech), 76 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#714976 01/25/2011 1:30 PM
What has anyone used for a rear trans mount installing a T5 in an AD? The stock mount only has 3/8" clearance under trans flange in my '48.
bowtiefan #715376 01/26/2011 4:31 PM
If you're running a 216/235 single mount/double bell housing mount setup using a cross member T5 mount is going to be counter-productive. With the 3 point mounting system the engine/transmission frame flex and stress on the T5 case is not an issue. When you snub the rear T5 mount down, even with adding a dropped cross-member, you're going to be loading up the already limited strength case.
If you're running a V8 with side motor mounts and a single rear transmission mount you'll want to fabricate a dropped crossmember that bolts up under the frame and uses the stock BW/Tremec mount. I have some pics of the cross member in one of my Webshot truck albums.
I base this info on my own experiences with my 235/T5 combo in a 54 AD which has run without a 4th mount (T5) for the past 13K miles. I fabricated a cross-member that could be dropped down when you pulled the transmission but never did tighten down the T5 rear mount. Hope this helps.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
