| | | Forums66 Topics128,108 Posts1,056,227 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 35 New Guy | | New Guy Joined: Dec 2009 Posts: 35 | Does the Right side arm and the left arm look the same other than being a left and right. The reason I ask is the ones I took off of the truck I have been restoring are a little different at the base of the arm and I see like lmc show two part numbers but I am assuming it is just because of the angle. Thanks | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i always thought they were the same, but that may be incorrect. i haven't paid attention which was which when reinstalling them. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | They are mirrors of each other, but not interchangeable from left to right, due to the minor offset angle on the end, receiving the blade. The wiper arms & blades sold by many of the aftermarket truck parts suppliers are close, but not quite the same, as their original counterparts. The blades are 13" and they were originally manufactured by Trico. They had a clear finish stainless steel finish on them. Each blade has tiny red release button on each end, to allow replacement of the blade, when refilling. | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | As Tony says, "they are mirrors of each other". Mine are aftermarket units which are adjustable for length and the angle of the blade.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | haha. i just thought about this after reading everyones comments, and i was wrong they aren't the same. they are so different i doubt you could install them wrong. i don't know what i was thinking, but i knew i didn't have to give it any thought when i put them back on. | | |
