1 members (Otto Skorzeny), 115 guests, and 0 robots.
Topics128,049
Posts1,055,549
Members48,425
#715156 01/26/2011 12:56 AM
Does the Right side arm and the left arm look the same other than being a left and right. The reason I ask is the ones I took off of the truck I have been restoring are a little different at the base of the arm and I see like lmc show two part numbers but I am assuming it is just because of the angle. Thanks
rodwst #715176 01/26/2011 1:37 AM
i always thought they were the same, but that may be incorrect. i haven't paid attention which was which when reinstalling them.
hoggyrubber #715184 01/26/2011 1:51 AM
They are mirrors of each other, but not interchangeable from left to right, due to the minor offset angle on the end, receiving the blade. The wiper arms & blades sold by many of the aftermarket truck parts suppliers are close, but not quite the same, as their original counterparts. The blades are 13" and they were originally manufactured by Trico. They had a clear finish stainless steel finish on them. Each blade has tiny red release button on each end, to allow replacement of the blade, when refilling.
As Tony says, "they are mirrors of each other". Mine are aftermarket units which are adjustable for length and the angle of the blade.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
starfire4 #715890 01/28/2011 2:43 AM
haha. i just thought about this after reading everyones comments, and i was wrong they aren't the same. they are so different i doubt you could install them wrong. i don't know what i was thinking, but i knew i didn't have to give it any thought when i put them back on.
