5 members (2-Ton, Ponchogl, 32Fordpuchoptop, dt235sd, 1 invisible), 102 guests, and 1 robot.
Topics128,049
Posts1,055,674
Hey guys,
I was test driving my neighbors 57 3100 the other day (trying to talk myself into it), and when I applied a good bit of throttle, it had one big backfire. The motor is a bored out 283 with corvette cams. but there is a exhaust leak where the manifold bolt to the actual exhaust pipe (3 bolts). the owner said the donut seal might be crooked. could this cause a backfire? he said it also might be running a little lean, but it cant be much because the idle is still a great low lope.
Alex
57' 3100 (The Bondo Bandit)
Bad rust and worse wiring, but so much fun.
Riding in the Passing Lane
It's dought ful the exhaust leak caused the backfire. It could be a lean condition or slow timing.
1972 Chevy c10 Cheyenne Super
Or in need of a valve job...
Or the shooter in the carb isn't working, which of course would cause a lean condition at full throttle and have nothing to do with the idle.
The accelerator pump probably is not giving a good shot of fuel.
how is this remedied?
Alex
With the engine off, remove the air cleaner off and pull the throttle open. The accelerator pump should shoot a stream of gas like a water pistol. If it doesn't, you need to overhaul the carburetor.
Y
yar Offline
Y Offline
Dalyman72, if the accelerator pump is shooting a weak stream or no stream a quick fix that costs nothing is oiling the accelerator pump leather plunger to restore its elasticity.
Ray
